Flooding the Air box?
RE: Flooding the Air box?
I just put OEM NGK plugs in, after I fixed the carb. #3 float was stuck...
The thing was it ran damm good when it was flooding.
Fix that and it sounds like its only on 3 cylinders.
Can my Fuel/Air screw be that big of a problem???
If anyone knows please give me the Jet specs.
Thanks,
Mike
Thanks,
Mike
I know that if you let it sit long enough the gas will varnish the carbs and continue to pour out. Alot of people will notice gas inside of the oil pan. I would make sure you have done a good 'couple' oil changes and make sure the plugs are covered. You might have to replace needles/jets.
