Finished my bike...pics
Things I did
powdercoated 6 spoke wheels
new michelin 2cts
painted fairings
rewired harness - all soldered connections
1000rr regulator rectifier
PAIR delete
secondary air delete
carbon heater delete
clean and sync carbs
new header
couldn't be happier, it's in the best shape now than at any point that i've owned it, love having a bike without a bunch of cosmetic or mechanical issues. just need to grab a slip on and install my steering damper
at her lowest during the rework
one with the mustang just cause
new michelin 2cts
painted fairings
PAIR delete
new header
it's a 600rr swingarm. not going to put decals on the fairing. I didn't mess with a tank because it has a big dent right at the crotch, I have another one to replace the one in the picture, just need to sand the clear off to get the decals off.
pair - 2 things you can do, just block the valve cover ports for PAIR with hose caps and plug the airbox at the rear port. or buy the block off plates from kyle racing, they are 30 dollars or so. I just capped mine.
secondary air - cap off the two small black tee ports on the front of the carbs. Also need to put a hose to a breather for crank case ventilation.
These two "mods" really clean up that area and shed a little weight
