f4 to f4i speedometer
Is there any way to change to the f4i speedometer??
would it require all new F4i Fairings?? Or do you think it would be a direct connect? I tried searching the DIYs.. but couldnt find anything..
It is not "direct connect". There are a couple of issues to resolve wiring-wise for the two systems to co-exist & for the gauges to indicate properly.
Also, the F4i gauge cluster is not a direct bolt-up to the F4 fairing stay. Those that have done the gauge swap typically have done the entire front end F4 to F4i conversion...that's front fairing, dual light setup, & gauge swap. However, I've also seen where just the gauges have been swapped out. There is some altercation & riggish-ment-stuff that you have to do to make the cluster fit & to secure it but it can be done.
I guess my post is supposed to be more encouragement than the referencing of how-to's. Whether I've accomplished this or not, I'm not sure.
Yeah i am thinking about a full F4i Front end Conversion as well.. Along with the F4i Seat conversion..
Might as well just make it a f4i huh?? HAHAHA!
How hard is the F4i Front end conversion?? I cant seem to work the Search function that well because every time i try to search for something it never comes up with the right thing..
Its like the Bing commercials... SEARCH OVERLOAD! HAHA
2000, cbr, change, conversion, difference, end, f4, f4i, fairing, front, gauge, honda, speedometer, stay, swap
