F4 backfiring at idle
Old 04-21-2019, 11:46 PM
Smartin's Avatar
Default F4 backfiring at idle
I have a 2000 f4 that backfires while idling at 1500rpm, and revs up hesitantly and very slowly up to 2000 rpm and smoothly but slower than it should from there. If I put the choke on to make it idle at 2000rpm, it doesn't backfire and will rev up smoothly, but not as quickly as it should. I just put in new plugs gapped to 35.
Old 04-22-2019, 07:26 AM
74demon's Avatar
Did it do it before you changed the plugs? What kind of plug did you use? Checking the gap on platinum or iridium plugs will ruin them.
Could be a carb issue. When was the last time they were cleaned and synchronized? Did the bike sir for a long period of time?
Old 04-22-2019, 05:01 PM
Smartin's Avatar
Before I changed the plugs it would barely start, only with very careful modulation of the throttle, a little starter fluid and full choke. It has been sitting for about a year, Prior to that it ran fine. When I changed the plugs I noticed the coil on #2 wasn't a snug fit, I couldn't feel it click into place like the others. So I had to pry out the little tab inside the coil to get a solid fit. Could it be that? 50k miles on bike, as far as I know carbs have never been cleaned or Sync'd.
Old 04-22-2019, 06:12 PM
74demon's Avatar
Sitting a year and have 50k on them? I would say they are due for some attention.
What did the old plugs look like?
Old 04-22-2019, 08:12 PM
Smartin's Avatar
They looked fine, and I was gonna put them back in, BUT after going through the PITA process of taking them out, I replaced them with new CR9EH-9. So I should pull the carbs and clean them? Or rebuild them?
Xavierf4
06-16-2018 09:42 PM
C-Kan
09-28-2012 06:47 PM
ike66
07-07-2011 04:50 PM
derboesekoenig
01-07-2010 10:12 PM
Quick Reply: F4 backfiring at idle
