Exhaust hanger
So I got back to my house after a ride the other day and realized my exhaust was hanging on by itself and the metal ring that clamps around the can had broken. I called two brothers, who are the makers of my slip on, and they told me my exhaust was so outdated that they didn't have a part for me. I have the round two brothers exhaust slip on from probably 2000ish...any ideas?
check ebay... I have seen some kind of carbon fiber hanger.. I know you dont need it.. but it would work.. also you can use a hanger from a Yoshi, Jardine, etc.. more than likely.. find a used one.
Just browsed ebay... I see a few round ones... but they are for pit bikes and scooters.. measure the diameter of yours.. see how large you need it..
Here is one that you might be able to just bend round (if it is long enough or not too long)
http://cgi.ebay.com/ebaymotors/ZX-GS...item335f476d3d
You can always fab up your own w/ sheet metal from your local home improvement store. Many of the track guys do this. Its not difficult. Sure, it won't be exactly super pretty but could work til you find a more permanent application for your situation.
Good luck.
Good luck.
sheet metal will rust, so make it out of stainless steel or aluminum. if you use aluminum you have to be careful, put a thin piece of rubber between the aluminum and the stainless exhaust, it will oxidize when those two come into contact for a long period of time. if it is not a stainless exhaust it does not matter but I would stick with stainless. find the exhaust close to yours and order the hanger, then fabricate from there.
