elec help
Hey guys I'm new to the forum and I've been having some electrical issues...hoping you guys could provide some insight.
some background info: First I kept blowing a fuse so I went thru and fixed whatever looked like it could be causing the problem, killed my battery, jumped it... fixed the lighting/fuse problem, but NOW my headlights and rear turn signals do not work, also the dash high beam indicator stays on regardless of the position of the switch.
The front signals work fine and are blinking fast also I can hear a clicking coming from the back.
Looked thru the wiring again and don't see any obvious problems.
Any ideas on where the problem could be or text I can do to narrow the problem? Thx
well think i found the problem the front headlight. left side melted, looking at wiring diagram the side that melted also connects to the rear turn signals. I'll try work on that over the next few days if get time... and will report back
check the entire harness very, very closely for a short to ground. pay even closer to the wiring around parts that move and flex while turning, harness to turn signals in the tail, and any wiring to and around anything not stock.
