Cylinder head gasket question
Hi there,
Haven't been since long on the forum.
I'm planning to check valve clearance, so I have bought Hotcams shim kit, and searching for head gasket.
While searching, I have found OEM one, alternative stated
same as OEM quality, and then I started wondering about laser cutting it.
I thought making it in copper with the same thickness.
Does anyone have experience on this?
I will keep researching.
Meanwhile, asking on this respectable forum.
TIA
TIA
No, gasket is not blown.
As I'm taking it apart, thought about placing new one.
Since I own the bike - 20 years- never had been done.
About multilayer, yes I know them. Always I thought they work as a spring - might be wrong -
Do you think it's possible to make a multilayer gasket, laser cutting it?
Ok. Let me add something to understand. I'm from Argentina, where parts are hard to get and a monthly average wage is around USD 300 now - if lucky-.
Cheers
Haven't been since so long on the forum, forgot completely how to reply. Hope this works.
Cheers
Cheers
So, if you don't have any crazy mods and wild tuning, no need to worry about headgasket.
Yes, MLS uses top & bottom layers of strong spring steel with moulded compression ridges. Then centre layer of mild-steel for proper spacing. When compressed, the ridges acts like spring where they push harder at contact surface for better seal. No need to use unless you have engine build that requires stronger than stock headgasket, such as turbo or nitrous.
Tooling to make MLS headgasket is quite expensive, not worth doing for less than 100 gaskets.
The following users liked this post:
cbrbike (08-21-2022)
