Clutch and Brake Lever Swap?
you may have ovrtightened the pivot bolt that the lever hangs on-
i dont know if this applies to your model but on any model:
look for the cable routing and make sure its not crimped or going around any odd angles-
lubricate-
tell how it goes and ill keep thinking.
nothing changed cablewise right?just lever-blade?not a fancy lever w. a return-assist spring that could get wonk?
best-o-luck
lubricate-
best-o-luck
-use a full box wrench or socket 6 point better than 12 - not an open ended wrench. (i wont mention pliers) on tough bolt-nut assemblies. this should be practice in general unless its a reach-angle problem.
STICKY LEVER-
make sure the cast barrel is properly seated in the lever.
tell us how it goes and ill keep thinking
best-o-luck
STICKY LEVER-
best-o-luck
