chain size
Sorry first off to what might be a dumb question, but I cannot find the answer.
I have a 1999 cbr600. i need a new chain. just gonna go stock. but what is stock size. 525 or 530 and it asks a size as well when you look. like 100-130. any help is greatly appreciated. J |
According to my Haynes manual the chain for your year and model CBR 600 is:
F-X and F-Y (1999 and 2000) models: Type: DID 525HV or RK 525ROZ1 Links: 110 links The later F-1/FS-1 models (2001 on) chains are: Type: DID 525H or RK GB525ROZ1 Links: 108 links Front engine socket size: 16 teeth Rear wheel socket size: European F-X and F-Y models: 44 teeth US 1999-2000 models size: 45 teeth. Hope this helps!
Originally Posted by mrclean667
(Post 1084926)
Recommendation
(Post 1084926)
I have a 1999 cbr600. i need a new chain. just gonna go stock. but what is stock size. 525 or 530 and it asks a size as well when you look. like 100-130. any help is greatly appreciated. J Highwaypatrol is spot on but If i could make a recommendation go with the RK XW 525 X-Ring chain. I had this on my old 98 f3 that had a 520 conversion and it felt great. You can find them much cheaper on ebay, theyre one of the best chains you can buy, and the x-ring performs much better than the standard o-ring you that came on your bike |
Very happy w/my RK XW 520 on my 9rr.... Three yrs strong!
Yep, I always get the RK chains now. Good chains.
Moved to F4 section.... |
Yep,
OEM 16/45 steel sprockets. OEM chains are D.I.D or RK 525 - both great chains. While the manual indicates 110 links, 108 is acceptable. (I personally use D.I.D gold on all my bikes.) |
| All times are GMT -5. The time now is 09:26 AM. |
