Cam Chain Tensioner problem? Common?
Yes.
Get this CBR F3 F4 F4i 600 900RR 919 Manual Cam Chain Tensioner | eBay and never worry about it again.
Yes, its a common issue. A little clicking is ok. Often times, after its warmed up it will go away. If its continual & getting louder, then its prob time to replace it.
You can replace w/a new Honda automatic type or aftermarket manual type (as CF has linked above). Both require some attention to detail but can be done at home.
The APE manual type is a good alternative. If your mechanically inclined, it is a good option. It needs to be installed & set properly.
I just want to point out that the newest version of the factory automatic CCT unit has been revised & upgraded...& should be a more reliable unit.
If a bike is burning up the new factory units, its possible the condition isn't a bad/defective CCT but cam chain related.
However, as CF has pointed out, the manual type somewhat bridges that gap by allowing manual adjustment.
The good thing about hearing that clicking/ticking on the F4 is that - you can go a long time b/f having to replace it...that is, unless its so loud that you can't hear yourself think. ;-) A little clicking tho, isn't going to hurt anything. Just be sure that it IS the CCT & not valve ticking.
