Broken down on road side! help
Old Oct 10, 2012 | 03:27 PM
cBrentb's Avatar
Ok, thanks I pulled plugs and 1,2 are whiter than 3and4. 3and4 are tanish color. There is only a whiteish color on 1and2. I'm looking at carbs now and ideas, without cracking them open?
Old Oct 10, 2012 | 03:36 PM
74demon's Avatar
Is there fuel in #1 and #2? full bowls worth...
Old Oct 10, 2012 | 03:53 PM
cBrentb's Avatar
Ok I'll check em for a park.
Old Oct 10, 2012 | 03:58 PM
cBrentb's Avatar
Yeah but, if 1 and 2 are white ish, doesn't that mean they have a spark ? And no fuel, the other 3 and 4 are brownish color like normal.
Old Oct 10, 2012 | 04:04 PM
74demon's Avatar
Correct. #1 and #2 are not getting the correct amount of fuel. Unless they're powdery white...thats something different altogether.
Old Oct 10, 2012 | 04:06 PM
74demon's Avatar
Could also be a vacuum leak around 1 and 2 resulting in too much air and not enough vacuum to pull fuel in...
Which could happen if a common vacuum line came off.
Old Oct 10, 2012 | 04:07 PM
cBrentb's Avatar
What if they are powdery white? What does that indicate?
Old Oct 10, 2012 | 04:11 PM
74demon's Avatar
burning oil or coolant.
Old Oct 10, 2012 | 06:22 PM
cBrentb's Avatar
ok, so im home now, afetr a break down on the highway then my phone crashed. after three hous of dianosing on the road i decided to call to get it towed in ...oh so much fun today.
heres where im at, looks like spark plugs 1 and 2 have a whitish tint no brown on them at all, 3 and 4 are fine so , im thinking no fuel at 1 and two. im out cleaning carbs now and checking that i get a spark on 1 and 2 plugs. any ideas from anyone in the meantime will be appreciated. brb
thanks
Old Oct 11, 2012 | 10:57 PM
cBrentb's Avatar
so im up and running again! wheew! cleaned carbs, replaced ignition coils, ignition coil harness, spark plugs (used die electric grease in connectors), checked all connections from ignition and start/ kill switch to coils (all good), took off the kick stand switch and cleaned the connections checked nuetral switch (all good). after charging the battery it fired right up. it runs noticably smoother now, this time i cleaned out the carbs on the diaphram, spring and needle side. its never been cleaned in fifty thousand miles. i cleaned literally a table spoon (not exagerating) amount of brownish black soot, sludge and bugs from under the rubber diaphrams. it was unbeleivable how much was backed up in there.
