battery drain problem 2000 cbr600f4
Im about to lose my mind here any info would be helpfull
my bike when i bought it seam to work fine i installed new mirrors with blinkers on them after that my bike seam to have battery drsin issues....so i had bought a new battery fully charged and rode it about 3 miles and parked to go into store came out bike wouldnt start....seemd i couldnt even get it going pish starting....so i got a jump and got it started and rode home about 2 miles.....lights and everything worked...got home still dead battery so i cjanged ricifter and stator....fully charged battery and started about 8 times then battery dead.......i unpluged blinkers re charged battery worked fine for few hours next day went out dead battery....RRRRRRR my thought is a short somewhere in wiring...someone else told me it could be the igniotion coil????hmmmm idk
please help me with any info thanks
Check out the following links, they'll help you get your head wrapped around how the
charging/electrical system works and how to do the diagnostics to pin-point your problem(s).
Just be methodical, don't bounce around, when doing electrical diagnostics.
Modern systems are inter-twined and something wrong "here", will actually be something going on "way over there".
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
These will get you started, feel free to drop back in with more questions.
Ern
Ern
