Any requests for "how to"s?
I figured I would ask you guys if any of you want a specific how-to for something on the F4.
Right now I'm working on:
Spark Plug Change (Should be done soonish)
Carburetor Synchronization (Should be done 6/14)
Sprocket and Chain Replacement (Should be done 6/15)
Plastic Repair (Should be done 6/16)
For example, earlier someone PMd me asking for a how to on removing the spark plugs, I sent him back a step-by-step to hold him over, but I won't have the pictures and officialish looking writeup done for a couple days.
Considering I bought my F4likethis:
(That pic was taken after I had pulled the engine, and put in new and unbroken front suspension, totally spaced taking one of what it looked like when I got it)
I can probably handle any kind of maintenance or upkeep stuff, but don't be ridiculous and ask me for a write up on shoehorning a busa engine into the cbr frame.
Let me know what you guys think
RE: Any requests for "how to"s?
ORIGINAL: Ktulu
you should put an f4i upper, and guage cluster and show the wire how to with pictures
looks like you have your work cut out for you good luck!
ORIGINAL: amaank
No requests here but props to you for doing all this.[sm=smiley32.gif]
If by fork rebuild you mean replacing the seals and bushings, I already did that write up, there's a link to it in my sig, it's in the how to forum.
Good idea on the valve check, I've got tons of pics of my heads when they were disassembled, I probably have enough to do a write up for them.
