Alarm/remote start help
Old May 29, 2009 | 11:35 AM
PALUMBOGIO's Avatar
Default Alarm/remote start help
HI!
I'm new to the post first of all I would like to introduce my self .
My name is Giovanni I own a 2000 f4.
I wont to thank all of you in advance.
I purchased a alarm/remote starter from eBay
The brand is alpha guards red flash the unit came whit the wiring diagram.
red=positive
black=negative
brown=positive 12v out
blue=engine start line
gray=off wire
pink=off wire
yellow= direction light
Fortunately I have a shop manual whit a wire schematics for the bike
I hook up all the wire from the alarm to the correct wire to the bike everything work except the remote start when I press the start button on the remote the bike try to crank but is enable to start .
I feel like that I'm missing something.
Attached Thumbnails Alarm/remote start help-alarm-002.jpg
Last edited by regener8ed; Feb 13, 2012 at 06:37 AM. Reason: removed offsite link; and ease up on the font, no need to yell.
Old May 31, 2009 | 03:41 PM
Cobrar980's Avatar
Well first off, is your bike cold? Your trying to remote start a carbureted engine, so obviously it won't start if choke isn't set, which makes a remote start virtually useless on a carbureted bike.
So the bike cranks but won't start?
What crank time is set, does the remote start have a tach check?
Honestly whatever that brand is, Alpha Guard or whatever, is junk. Buy a Directed unit, like viper.
Old May 31, 2009 | 07:10 PM
CB750's Avatar
Yes, set choke and try again. You may have to choke it when you park.
Old May 31, 2009 | 08:12 PM
PALUMBOGIO's Avatar
I try whit a worm bike still no crank my be the fuel pump doesn't receive any power I need check on that regarding the tach check I don't know the alarm schematics doesn't say anything on that.
Old Jun 1, 2009 | 08:47 AM
Cobrar980's Avatar
Well, on a remote start, you typically power ignition and accessory, so basically whatever show's 12volts when the key is turned to on should be powered up. So you need to make sure you have everything powering up. Obviously you found the starter wire, did you tap ignition? There could be ignition 1 and 2 on the bike, make sure both are powered. That will ensure that all starting components are working during remote start
Old Jun 1, 2009 | 10:15 AM
Falqon's Avatar
I doubt he needs it choked in NC. In Atlanta i haven't bothered with the choke for the last month.
Old Jun 3, 2009 | 07:51 PM
limpy88's Avatar
the neutral and sidestand switchs could be giving problems
Old Jun 4, 2009 | 04:26 PM
Cobrar980's Avatar
My only thoughts on that is in the fact the bike is cranking, if all that is connected improperly, I'm pretty sure the bike wouldn't even try to crank.
Old Feb 13, 2012 | 01:11 AM
Cbr929rrrr's Avatar
is it fuel injected?
Old Feb 13, 2012 | 06:11 AM
Acespad3's Avatar
i believe its carb'd if im not mistaken, the F4i's were fuel injected. if its cranking but wont start, then its fuel related. double check all your connections with the remote start/alarm system, make sure you have your grounds grounded.. but dont forget to check the basics like your fuel petcock being on (pointed down)
