99' F4 Headlight issue
Let me ask you this;
When you solder the ground, how are you doing it? Are you melting the solder directly to the ground? If so, that could be your issue. It's called a cold solder joint and it wont last.
The process is to heat up the material and then lay the solder onto that surface. The solder will melt onto the surface once it gets hot enough. This forms the proper bond.
Hope that helps.
Hope that helps.
