99 f4 carb problem/fuel problem
So I stunt mine 99 Honda f4 over a month back before ROC in St. Louis my bike wouldn’t idle right would bounce between one and 2K. Would Idol at 2200k and not bounce around if adjust it up. It would wheelie just fine had a little bit of loss of power I noticed. I got my carburetor synced after a while after that it would start good cold and run normal idle and not bounce. Did not backfire. But I would only ride A wheelie for like 10 seconds 20 seconds then bog out. Wyatt to work in the morning was pretty cold bike made it there fine on my way home mid day it was pretty hot out what I was doing some wheelies on back roads it was doing fine. Would bog after like 10/20 seconds., he ended up backfiring super loud like three or 4 times Then Rd. probably couple more miles and then completely die had a pop started because my starter is not working. Ran like complete **** how to stay on the throttle a lot it would backfire very loud I don’t know what my issue is ☹️.
So it all started when the battery didnt want to hold a charge a little over a week ago. My bike tends to stall out sometimes in traffic, and when it did, it would drain the battery completely. I had to jump the bike a few times but after a 100mile ride to my parents house the battery began holding a charge again. The bike was running like it always would, a little rough in traffic but great out in the backroads. Then all of a sudden while riding I lose all throttle response. In fear of what might be happening, I pull the clutch in and the bike dies after coasting into a parking lot. I try to start it up and it will crank but wont start. I tried run starting it and it backfired loudly and started momentarily but died. I was not able to get it running again after this. This seemed like all the symptoms of a fuel issue so i replaced the fuel pump. Still will crank but wont start. I have no idea why it wont start. Any ideas?
