-2,+1..bad for a beginner?
so my new bike has the lower gear ratio and i was wondering if you guys think its a mistake to learn with it like this, or if it really even makes that much of a difference, ive only ridden for a few mins and the low is pretty torquey but i dont think its anything that i couldnt get used to..
RE: -2,+1..bad for a beginner?
No - you can get used to it fine - but it's going to be a wheelie spittin' sunsabitch. The F4 is front-light already, dropping two in the front and adding one in the rear? Gonna be worse than an F4i.
Again- nothing you can't learn on, but the bike will be a lot less forgiving if/when you make a mistakewhile cornering/turning.
ORIGINAL: MikeMirage
That "going to be worse than an f4i thing" is stupid. The f4i makes only a few more horsepower.
If you'd read the goddamned post you'd ****ing know that. I'm so sick of you ignorant bitches calling someone stupid or putting someone downas a result of your own inability to read the written English language.
Now **** off and wad your bike up then write some unimportant farewell post in the Off-Topic section.
Back to the thread for a new rider I would not suggest this sprocket combination. As said before the bike will be wheelie happy as all hell. Being a new rider you need to learn throttle control and what not before attempting to control a wheelie happy bike. I personally would take the bike back to either the stock size sprockets or just go down on tooth on the front. Keep in mind that -1 tooth in the front equal roughly +3 teeth in the back.
Well this might not exactly apply to me since I've been riding since I was 6 (well mostly dirtbikes but thats beside the point). However my 2000 F4 is my first street bike. I bought it with all the original stuff on it (chain/sprockets etc...). As of this summer I went to a 520 conversion with a new chain and a JT sprocket set where my front has one less tooth and the rear has three more. I put about 2500 miles on the old set up and about 2000 now on the new. It is a noticable difference, especially at the low end. You will loose top end, but who needs to do 160 mph anyways??? I like the grunt it gives at the low end and the fact that pulling up the front wheel comes with ease. The only problem is that the speedo is off and the mileage isn't correct, but a speedo healer can fix that. I don't think the difference is extreme, but I would wait awhile to change your gearing. Get used to the stock set up at first and then do a possible conversion after that.
