Originally Posted by dannoxyz
(Post 1352827)
Well, wire can be broken internally and not show any faults on outside. We'll have you test and measure every wire with multimeter later.
1. how have you verified no-spark? 2. is there petrol flow to carbs? as in measured fuel-pump flow for 10-sec? How much did you collect? 3. disconnect ignition-module, key ON, measure voltage at black wire terminal at connector. Volts=??? 4. measure resistance to chassis-ground of grn wire at connector. ohms = ??? 5. measure resistance to chassis-ground of lite-grn wire at connector. ohms = ?? I'm not a mechanic but I can usually sort this kind of crap out. I ended up installing a fuel injected 2005 gsxr 750 motor I had running on a stand. I just want to get this figured before I die or it gets tossed in the trash. 🤣 |
Originally Posted by David43Abq
(Post 869236)
FINALLY !!!!!!!!!!!!!! It's ALIVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
anyone who ever has a no spark issue on a Honda motorcycle, please read !!!!!!! There is a diode in the switch base of the ignition switch. IF that diode pops for any reason you will have a no spark/no fuel pump issue. The value of the diode is 3.9v 0.5watt part number NTE5007A. My 99 will be back on the road soon !!!!!!!! yay ... btw, it's a friggin .39 cent part ... |
Originally Posted by Ryan1985
(Post 1353221)
I cut my ignition wires cuz lost key so im having same issues do i need that diode to get spark regardless??
(Post 869236)
Thanks for the update and welcome to the forum.
That resistor is the cause of many problems with these bikes, esp when installing aftermarket ignitions onto them. |
It's not a resister - it never was a resister - it's a DIODE. Its job is to reduce the battery voltage to 9v to trigger the ECU to understand the ignition switch has not been bypassed. It's an anti-theft measure.
Sorry, my bad, yes a zener diode!
Originally Posted by Al1040
(Post 1361395)
if vibration is causing it to fail then I expect so - it will cause the ECU to crap out.
Originally Posted by rockpool
(Post 1361550)
| All times are GMT -5. The time now is 02:38 AM. |
