1999 CBR 600F4 wont start
Hi all. Im new to the forum and hoping to get some help on here. I bought this bike dirt cheap and running just fine. The key was lost so I bought a new ignition and tank lid. Put the new ignition on and it would start. The wires were different colors. I put the old ignition back on and it started just fine. A couple of weeks later, nothing. It wouldnt start again. This time i got a new started relay and solenoid(with plug) and wire it up as best as i could and got absolutely no power to the fuel pump but the bike would turn over. I checked the fuel pump and found it was bad so I replaced it.
So now I currently have the old ignition, new fuel pump, and new started solenoid. Now the fuel pump is pumping just fine but the bike wont fire up. I havent messed with any air/fuel settings. I feel the issue is going to be in the wiring config that i have for the starter solenoid since they are different colors. Im posting a pic. I am sure someone has had this same issue. there are no clear color coordination instructions on which wire goes where. Also, Im posting links to the exact parts that I bought.
Gas Cap and ignition
Fuel pump
Starter Relay
This is a pic of the wires going to the relay
https://imgur.com/kHQvhz3
this is one of the bike's harness:
Any help would be greatly appreciated. Also, I pulled the plug wires to see if they were getting power and they are.
Fuel pump
Starter Relay
Hi, to the best of my knowledge this should be your wiring codes to the Chinese Solenoid, should only be 4 wires but in one of your pictures shows 2 RED wires , were these spliced together beforehand, one of those runs direct to the ignition switch, you might need a multimeter to find which of the 2 it is
