Yes, its another fuel question!
Ok, so the gas station down the road from me has 91 non oxygenated fuel(Yes, I did use the search and only "oxygenated fuel" came up). I've been looking at google for the last couple hours and haven't found a pros and cons to useing this fuel in my bike. The only thing I saw was people saying they got about 3-5 more mpg in there cars.
At the pump there is a sign that states non oxygenated fuel "only for off-road vehicles, boats, motorcycles, or antique cars".
So my question is since I have the option to use 91 non oxygenated fuel here in MN, should I use that over staight up 87?
Moses
Moses
Re: Fuel Question
The only difference in the fuels is how much they are refined. The reason the sign says for off road use is because the process they use to make it does not require as much as it does for highway use( good ole EPA for you) It really shouldn't make any difference in using the 91 octane besides a few extra mpg and a few more impurities in the fuel. I'd say go with it save the money if you can.
All it means is that it's not "oxygenated" with ethanol.
If there was a station near my house that still sold the stuff....... yeah, I'd use it in the bike. Fuel economy will be better because it has more energy content.
I ended up putting a tank full in yesterday. I happened to run into the truck driver that was filling up the gas stations tanks. He told me that its "no ethanol fuel" he than added that when using it, it won't leave any varnish in my carbs like ethanol based fuel does. I'm not sure if this is true but it sounded good
So you would run it 24/7 then? Being I'm from MN my bike is a seasonal toy, so I don't mind the little extra cost for fuel if its a better choice to run.
Ty Guys
Moses
Wish, yeah... I'd run it all the time if it were me. But.. it also depends on the price. If it's a lot more money, I'd have to think about it.
What the fuel guy said is kinda true and kinda not (the way I've always understood ethanol blends)
The main problems with ethanol (E10) gas is that it gives you less gas mileage (btu content is less), it can attract water vapor, and it evaporates quicker which leaves more residue/varnish behind.
However, it can also dissolve some varnishes with the alcohol it contains.
Does E10 suck vs. regular gas? IMO, sure it does.
However, I pretty much run whatever gas I can find, but if I'm gonna be storing my bikes for any amount of time at all I make sure to add a bit of seafoam (or stabil), and make sure that the tank is full of fuel. Since ethanol can draw in moisture, it can create condensate and rust your tank as well as leave some residue behind in your system. I also run about a bottle or two of seafoam through my bikes each year and my carbs/tank have seemed to stay very clean.
i always run 93 octane unless its in the four wheeler, but i beat the crap out of that thing
