Won't fire up
If you put it away and she was running fine, and it had no other issues prior to this then I would suggest checking your battery readings first. I won`t mention the fuel or tap as I`m sure you`ve done that. Measure before starting and continue to read as you hit the start button. Just because its turning over does not mean there`s enough juice to actually fire her up. Once you know you have a good battery you can check plugs etc and move on. Your post doesnt give much away (which bike?) so people here probably would want more info to help you out. Best of luck mate
She died on me at lights for about 30secs last time I was out, but started after two attempts.
Not much to say, 3wks of sitting and as above, turns and tries to start but won't. Cheers.
It was down on power, but was picking up a tad the more I opened it up (guessing the carbs got a bit of self cleaning) and I have a blow in the header pipes, which are rotted quite badly.
One thing I noticed was it took an age to get up to full operating temp, but that could be cos I was used to the crazy hot engine in the Ninja?
No, I know nothing about it, I only took it in part exchange to get rid of a zx12r I had (hated that thing!) I haven't touched it. It was starting fine 3 or so weeks ago.
the engine should take awhile to get hot that means the coolant is working correctly
Can't where I live mate, it's an extremely busy country feeder road into Dublin and I've no-one to help me push it, and if I ran it down myself and it didn't start I'd have a 60 degree gradient and 100yd driveway to push it up!
