wiring problem
Ok i think i messed up when i was connecting my LED break light. The turn signals in the back are somehow messed up. When i want to show someone that i am turning right or left both of the indicators go off above the gauges. None of the turn signals even turn on. The rear right is the one im having a problem with i think. The left i didnt touch. I have two wires coming out of the left (rear and front) and three wires coming out on the right (rear and front).
The cables in the back that i have to connect to are two green ones and a black one. the turn signal cables are two black and one red. If its too confusing to anyone, im sorry but this is the best i can do. Anyone have a wiring diagram for those? Thanx alot for ur help. |
RE: wiring problem
If you were changing just the brake light why did you have to mess with the right turn signal wires?
RE: wiring problem
what happened was that when i got the bike, the dealer didnt exactly tell me everything. The rear cowl and the whole light assembly was attached to the bike with some homemade aluminium brackets. well 3weeks after i was riding it, the whole thing fell off and started bouncing on the tire up and down up and down, when i was going about 30mph. That messed up my side rear fairings and the wires from the light. it wasnt pretty. and thats basically why i had to play with the wires that messed me up.
RE: wiring problem
I see... I would try to find a wiring diagrams or get a volt/ohm meter and figure what wires do what. Other than that is hard to help you without being there to test the wires.
