will not start!
Old Apr 17, 2009 | 07:06 PM
Adamavage's Avatar
Angry will not start!
Havent started the bike since rebuild. I already cleaned the carbs new fuel lines and all of that. Gets plenty of spark at wires didn't pull plugs out yet. Any ideas?
Old Apr 19, 2009 | 02:08 PM
Endless's Avatar
Siggy Maker & All Round Good Guy
What kind of rebuild was it?
Old Apr 19, 2009 | 07:19 PM
Adamavage's Avatar
Default ecerything
A complete rebuild minus the electrical. But I had gotten the bike started after replacing the ecu and some fuses off a parts bike.
Old Apr 19, 2009 | 08:45 PM
ominous1's Avatar
just cause this happend to a freind of mine, is the gas on? does it turn over?
Old Apr 19, 2009 | 10:04 PM
Adamavage's Avatar
Yea gas was on turned over fine was just electrical issue I guess like I said I swaped out the ecu from a parts bike and change some fuses and it started right up
Old Apr 20, 2009 | 08:30 PM
Endless's Avatar
Spark
ignition (fuel)
compression
Exhaust
The process of an internal combustion engine.
If it is not any of those than you have an electrical problem.
sounds electric since you had it going then it suddenly did not want to fire.
Old Apr 21, 2009 | 12:13 AM
f3BikeR's Avatar
Wink
Originally Posted by Endless
Spark
ignition (fuel)
compression
Exhaust
air
fuel
correctly timed spark
compression
Old Apr 21, 2009 | 06:37 PM
Endless's Avatar
well, if you want to be that way. The book lists this order:
1. Intake
2.Compression
3. power (spark)
4. Exhaust
FOUR STROKE ENGINE PRINCIPLES
Old Apr 21, 2009 | 11:52 PM
f3BikeR's Avatar
1. Intake
2.Compression
3. power (spark)
4. Exhaust
no fuel?
intake sounds like "air"
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
