Where is the thermostat valve on my F3?
I just bit the bullet and bought a Motion Pro sync tool. But it's really not overly complicated. I can describe one design I was think of using. You'll need:
You drill 2 holes in each stopper. Fill both bottles to about 1/2 with your liquid. Put the stopper in the bottles, sealing them. Take one hose and connect the two bottles together, with the ends of the hoses going all the way to the bottom of the bottles. Then put a hose into the open hole in each stopper so its just through the stopper, clear of the liquid.
The free hoses attach to the two carbs you're trying to balance. What happens is vacuum created by the engine pulls on the liquid in the bottles. The hose between the two bottles attempts to equalize the pressure, transferring the liquid between the bottles. If 1 carb is pulling harder than the other, the liquid in that bottle will rise higher. Because the two carbs are pulling against each other through the tube connecting the bottles, the liguid can't be pulled into the engine.
From there it's just adjusting the carbs till the liquid in the bottles are equal in the bottles.
- 3 hoses
- 2 glass bottles
- 2 rubber stoppers
- a drill bit slight smaller in diameter than the hoses
- Liquid (don't worry about the type)
