where the heck can I go to order a 14 t front sprocket
I just want to order a 14 t front sprocket and a couple oem oil filters for my F3, but where?
The oil filter is a no brainer, but since the front sprocket is a -1 tooth, I don't know where to go.
I already have an account with www.ronayers.com, but I don't see where I can get just the 14t front sprocket without buying a set.
the same chain will be fine i never had to get a new chain when i went 1 down in the front ...... you can get one from the honda shop for like 16 bucks and i don't think it matters what chain you have i may be wrong but i don't think it will ..... i just told them what i wanted and they got it for me ..............i hope this helps ........ when you put it on you will see why i say go 2 up in the back !
the previous owner of my 2005f4i had done a +1 rear and a -1 front. He said the -1 was too much for him so he put stock back on up front.Now how hard is it to put the -1 back on to see if i like it and can i use same chain thatd on it now, or have to change whole setup..?
a word of advice.
when you change out the chain, change the sprockets with them as well as a whole package deal.
you can get a pair of sprockets for 30 bucks on ebay (JT) and a chain for 50 or less.
80 bucks or less for the whole set if you shop around
make sure you have a o-ring chain.
standard chains are terrible.
if you can afford on id get a rivet and avoid the masterlink.
