where to buy f3 regulator female plug?
If the regulator plug is burned up, you'll need to replace the regulator.
The GsxR's will do the job or Honda upgraded the part as well (added
heat fins). I actually bought a new after-market replacement from
Electrosport. Instead of hunting down the gang-plug, I used individual
female bayonets on each wire with heat-shrink to insulate them.
Ern
Ern
OEM-Type Bullet & Spade Electrical Connectors for 1960's through 1970's Japanese Vehicles... Bridgestone, Datsun, Hodaka, Honda, Kawasaki, Landcruiser, Suzuki, Tohatsu, VW, & Yamaha
Gotcbr turned me on to that one. Excellent resource, fast turn-around.
I used them to pick-up the 9x connectors I needed for my guage conversion.
18 wires is worth using a pair of plug-connectors, I didn't think 5 wires on the
r/r justified the cost/time. I'm just gonna cram them full of di-electric grease
to waterproof them.
ElectroSport - Motorcycle, Dirt Bike and ATV - OEM Quality Stators, Regulator/rectifiers and CDIs
Here's where I picked up my r/r.
The r/r came with the attached plug ends you see. Since it's only 5 wires,
I used individual bayonet-mounts on them. I used heat-shrink tubing to
clean it up and insulate the soldered on plug-ends.
Hope this helps, Ern
to waterproof them.
