what is wrong with this thing?
Old Oct 17, 2011 | 02:50 PM
deedub97GT's Avatar
Originally Posted by Mrmanr
Can you start the bike in gear without pressing in clutch?just wondering
no it wont.
Originally Posted by spicymeowmix
my bike would die when the R/R wires burned out while riding.
(the battery died)
i was under the impression that as long as i started the bike and kept it running it would be fine like most cars,
however when i pulled in the clutch the bike would die.
i wouldnt say that's your problem, however id say i know the feeling.
i dont really know how to help you in this situation... if its going from heavy rpm while riding to idle when you pull the clutch in, occasionally my bike will dip BELOW the idle speed... i keep my idle at 1500... and ive seen it go as low as 1k before from doing that.
if your bike idles at 1k, and your bike acts like mine, it could dip below idle when you pull the clutch in also, but so low that the bike cuts off.... see where im going with this? thats why i suggested upping your idle...
i rejetted, and resync'ed and adjusted the idle mixture screws.. and i havent had that problem since.
i havent even thought about my r/r being burned out...and my battery was mysteriously dead the other day. im going to check this out real fast.
Old Oct 17, 2011 | 04:49 PM
deedub97GT's Avatar
my r/r was fine. i upped my idle and it only died on the clutch once. and even then it bounced off just below 1k beforee it died. i might just have to play with my idle. thanks guys!
Old Oct 17, 2011 | 05:04 PM
HenryM's Avatar
Have you checked the side stand switch?
It sounds as though there's a wiring fault here. Have you checked the clutch switch to make sure it's switch lines are not shorting to ground?
Both are linked to the rectifier on one side of its input and also the ignition control module.
This may be a good train of thought/exploration.
Old Oct 17, 2011 | 06:26 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
i wouldnt call it a permanent fix, but it will buy you some riding time to figure out whats wrong
Old Jan 11, 2012 | 08:38 AM
Scatman200's Avatar
This sounds like a switch issue right off the bat. You said you can't start it without pulling the clutch in (it should be able to though) which supports this theory as well. If you we closer I'd pull my stand/clutch perch and help you troubleshoot, unless a ride to CT is in your future...
Keep us posted
scaredem23
Jun 14, 2010 07:33 PM
Rod38um
Jul 23, 2009 12:56 AM
cyber00677
Apr 11, 2008 03:35 PM
Rubicon on 38s
Nov 17, 2007 05:18 PM
sixs929
Apr 18, 2006 04:22 PM
