What does this connect to?
Old May 20, 2013 | 04:46 PM
ekko's Avatar
New Member
Exclamation What does this connect to?
Hi everyone, just got myself an f3 and trying to go through it and fix a couple things here and there. Previous had nothing connected to this part and there is fuel coming out of here. Can you guys tell me what this part is supposed to connect to? Thanks!
https://www.dropbox.com/s/xgr6ir5wh78f261/photo.JPG
Old May 20, 2013 | 07:33 PM
Duck62's Avatar
That is part of the high speed/low speed circuit for the carbs. There is a way to reroute it. It needs to be used.
Old May 20, 2013 | 08:06 PM
ekko's Avatar
New Member
Thanks duck62, do you know where I should reroute it to? Is it proper that gas is flowing out of that tube?
Old May 21, 2013 | 06:54 AM
Duck62's Avatar
Take a look at a service manual for the routing. If you want to eliminate most of it and the solenoid, you can look at the 5th picture on this page. HRC mods - a set on Flickr
As for the fuel leaking out, you may need to clean the carbs. Sounds like the float valves may be stuck open.
Emmanuel Lind Chrisalos
Feb 25, 2014 07:26 PM
cschew
Aug 21, 2013 01:13 AM
coldflood
Sep 3, 2011 09:06 AM
LJ Harp
Oct 6, 2010 02:06 PM
