pacemaker |
09-07-2010 01:49 AM |
Weird, Weird, Weird. Dipstick
Got home this arvo & decided to check my oil, only did an oil change not so long ago but you never know. Anyway went to try & undo the bloody dip stick & the bugger has been hard to shift before, but this time I ended up having to use a large adjustable spanner just to get the thing to move. Thought to myself I must have cross threaded last time. Got the thing out, no, the threads are perfect. Had a look inside the internal threads (not that it could have done any damage as the dip stick threads are plastic) No problems with that either.
So checked the oil & went to screw the dip stick back in & it's like it's from another bike, 2-3 turns & the thing is getting tight!!. (even put a small dab of oil round the threads. Now I've removed the dip stick in the past 12 years dozens of times & have always been careful in replacing it back. Its not like some of those old plastic dipsticks where the top fits into the cap & can turn, this thing (apart from the metal band) is one solid piece. P*ss*d off as put a small mark on the bloody casing getting the f*ck*r out :( Going to order a new one, but weird stuff.
The only think I can think of is, does the plastic expands with age or something? Anyone else out there experienced this phenomenon.
