Valve clearance or should i say lack there of
Finally got a chance to check the valve clearance this morning and found that on 7 of the intake valves the cam is touching the bucket i cant even get the .038mm blade to fit in there. How do I go about in figuring the math for shims if I have no clearance to start with.
So i finally had some time over vacation to measure the valve shims. Most are right around 2.09 to 2.13. The smallest is 2.05. So it looks like the only way to figure out what I need is to swap shims and measure clearance Or just try to get any clearance would be to put the 2.05 in each bucket put it back together and check it just to see if thats enough. But to do this 15 times I just don't have the time. What would a shop do in a case like this. And do any of you have any ideas on another way to figure this out. thanks
I was thinking I was going to end up doing it that way. Was wondering if anybody had any 2.05 or smaller shims laying around as I will gladdly buy them. And really if I have to do it with the one 2.05 I have, only the 8 valves on the intake side have no clearance as the exaust side is within tolerance. I really wish there was a mechanic that I trusted in the area I could save myself alot of time as I have very little time to
work on the bike. You would not believe the things that I have experienced through the years at all of the local bike shops these guys have no idea how to do things correctly.
It might be worth it to get a shim kit, for your bike. If you do it yourself, you'll save
running to the dealership and back, for the correct ones.. It will, also, give you a
variety of extras to drop in, to get the clearence for the tight valves. They run about
70-80 bucks, and are worth the time they save running around (imo).
Good luck which-ever way you go.
Ern
Ern
See what you have and subtract the 0.16 mm from them, so 2.025 -.16 = 1.865 mm as the shim size you'd need to install. Honda only makes them in certain sizes in .025 increments. 1.865 is between 1.850 and 1.875.
Now, here's what I'd do. I'd go with the 1.875 size, Honda part number 14928-KT7-013 which would make the clearance error on the side of being tighter rather than looser. You may wonder why I'd make that choice. As the engine warms up, the valve clearance increases, so they loosen up (this is why the engine needs to have sat for 24 hours without running before measuring the clearance). Also, you said that you couldn't get a 0.038 blade into the gap. Well, that's still not zero and there could be some amount of gap that you're not able to measure.
Do this calculation for each of the shims you currently have and replace them with the newly calculated shims. This method should put you really close to where you need to be.
