Valve adjustment at 16 K . Advice needed.
Old 06-27-2007, 01:14 PM
land_warrior.rus's Avatar
Default Valve adjustment at 16 K . Advice needed.
My cbr just past its 16k mark on the clocks and as far as i know valves need to be checked and adjusted. I owned bikes before and had it done myself with no problem. But cbrs don't have adjusting screws, honda decided to go with shims instead. So i just wanted to know if i check my valves with the feeler gage and the gaps are off where do i get this shims from? If someone has some advice on the whole valve adjustment thing as well i'll be very greatfull. Cheers.
Old 06-27-2007, 04:46 PM
Default RE: Valve adjustment at 16 K . Advice needed.
What? Noone did the valves? Hope somene did. Thanks for looking at the post any way. Cheers.
Old 06-27-2007, 04:59 PM
When mine has done 16k I think I will take it to the dealers and let them worry about it, would be interesting to get an answer though, someone must know.
Old 06-27-2007, 05:54 PM
Sorry mate, don't trust dealers. Always did all the jobs myself. Just every now and then run into one of this problems. Not knowing where to the part. The job itself isn't to big or hard. Just have to be a bit more careful comparing to changing the brake pads ;-) cheers.
Old 06-27-2007, 06:23 PM
http://cbrworld.net/forums/post/246254.aspx
Have fun.
Old 06-27-2007, 07:04 PM
when we did mine only but 500 mile ago they were all fine
Old 06-27-2007, 07:58 PM
Super. Thanks guys.When i get my shed/work shop in i'll get this done and may do a post here then.
Thanks again.
Old 06-28-2007, 12:30 AM
jbreit's Avatar
shims from Hot cams....way cheaper than OEM...though you need to buy a large assortment, if you have more than 5 or 6 valves out, it will work out cheaper.
I have a pretty good assortment built up myself.
Old 06-29-2007, 03:36 PM
Thanks for the info.
Old 07-10-2007, 09:14 AM
I need to do the valve adjustment on my wifes F3 as well. The post that LlanoSV put up was great. It explained a lot. I agree withyou that I don't trust dealers. I don't think that anyone will do as good a job as you would do yourself. This is certainly a job that can be done and save money for more important things. land_warrior.rus, do you have a time frame of when you're going to be doing this on yours ? Just curious.
Quick Reply: Valve adjustment at 16 K . Advice needed.
