Toasty! (Yes another R/R thread)
Old May 2, 2010 | 09:40 AM
Mikey97F3's Avatar
Default Toasty! (Yes another R/R thread)
Ok a little back story...(97 F3)
I rode to work the other day, no problems. Started up and ran fine for the ride home. Decided to go visit my Mom at her house, and when I go to leave there's no juice to even crank the motor. So I throw the battery charger on for a few minutes and get it started, ride it home. Later on in the evening out of curiosity I try starting my bike and it fires right up. So, I ride for about 45 mins. and towards the end of my ride I'm noticing the bike acting very strange - headlight dimming when the turn signals click on, LED body lights are dim or not on at all...and starting out into first gear the bike almost stalls. Well, I was nervous to say the least that I wouldn't get it home...luckily I did. So the next day I decide to do a little troubleshooting. I walk out to the garage with multimeter in hand. Battery was near completely dead - charged it. I take the tail plastic off to inspect the regulator/rectifier. At first glance it looked fine but upon removing the wire harness I find this
Obviously things got a little heated in that plug. The wire that was connected to the toasted pin was a stator lead and had completely burnt itself up, no connection whatsoever. I checked the resistance across the stator leads while I had the plug out and they were all about 0.5 ohms - from what I read on this forum that is within the "good" range so I am assuming the stator is still good. I am going to replace the R/R with a GSXR unit from ebay and hardwire it on. Hopefully this will solve the problem!
So, what I want to say is Thank you to all the members of this forum for the information that gets posted here. Without forums like this I would probably be so lost and discouraged that I would want to just give up on the bike lol. But, thanks to all the members here I was able to diagnose and identify the problem with almost no effort, plus I got the info I needed to fix the issue. I owe you guys! I'm hoping to be up and running again within a week. Thanks again folks!
Old May 2, 2010 | 02:03 PM
Good choice on the GSX/R replacement. That connector probably burned up due to a loose or corroded connection. The fact that you're going to solder it up will take care of that. Looks like you've got this all figured out. Good job.
phillymac
Apr 23, 2011 10:02 PM
tjay
Apr 12, 2011 01:12 PM
rustyeffect
Jun 19, 2010 08:31 AM
Monstrosity
Oct 8, 2009 09:46 PM
Relff2
Sep 28, 2006 11:09 PM
