| IDoDirt |
May 25, 2009 08:17 AM |
First off, I recommend downloading the shop manual if you don't already have it. Search the site, it's an easy find. Then look at page 1-22. It gives you an idea of how they're supposed to route.
The thing that I've learned about the throttle cables is that what you're adjusting is the cable housing or sleeve, not the cable itself. They need to be loose enough to allow the cable inside to move easily. The manual says there should be between 2-6mm of throttle play in the cable. The upper end of the cable housing near the throttle is for smaller adjustments. The lower end near the carburetors is for larger adjustments. The cables should be routed smoothly and should stay relative to each other, meaning they shouldn't cross each other. Unfortunately I don't have any photos to post up.
