Is there a vacuum line from the carb to tank?
Hey guys so my petcock is leaking and theres nothing I can do about it cause its riveted on and I have an extra petcock from a 97 cbr900 that needs a vacuum line unlike the f3. So question is, anyone have a solution for this?
Thanks Justin |
Get a used tank and petcock from ebay. Or plug the vac line on the 900 petcock and see if it works. Good luck
Plugging the 900 petcock won't work.
Running a hose off of the #2 carb manifold should though. I say #2 because it should have a capped nipple already on it. Ern |
Originally Posted by MadHattr059
(Post 1236353)
At about 7 o'clock on the intake throat
Shine a torch into the area you should be able to see number 2 quite easily |
Carbs/cylinders are 1-4 left to right.
The ports are just below the carbs. #1 usually has a screw cap in it. #2 should have a nipple with a teeny-weeny hose clamp on a rubber cap. Best do this when the bike is cool. It gets pretty toasty in that restricted space. Ern |
Awesome guys thanks a ton, I got her running good!!
