Is there a difference between the 1995-96 and the 97-99 f3 heads?
I am running a hondar f3 motor the minisprint car that I bought to race this season. Can someone tell me if there is any difference between the heads on a 95-96 and the 97-99 f3 motors? I know there were some changes on the bikes but not sure about the motors.. Thank you!
From what I can tell the 97 just uses a different spring setup with less parts and longer uncompressed spring length, but I would be careful interchanging parts on one head to another.
Manual says:
"Install and tighten the cylinder head bolts in a crisscross pattern in 2-3 steps"
Usually, if there is not a sequence given, then you'd start from the inner most bolts working outward in succession. Spec is 35 lb-ft. for head bolts.
