Temp Sensor with f4i gauges
Old 12-16-2009, 01:08 PM
Michael S's Avatar
Originally Posted by rothjl749
I started to work on this last night. I thought that a baby thermometer would give me an accurate measurement of the water temp. When I tested the water, the thermometer told me the highly accurate measurement of "HI" I guess I will be by the store to buy a dial thermometer tonight.
That's so funny!
Old 12-16-2009, 03:04 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
I put the bike inside my house for a few days to get a more exact reading than before
House @ 65*f
Bike @ 249*f
That should create a total difference of 184*f
Old 12-16-2009, 03:28 PM
chuckbear's Avatar
You guys are assuming that these differences are constant, right? Are you sure that's how it works? How do you know it's not proportional?
I'm not saying you're wrong, but just throwing it out as food for thought.
In other words, you guys are assuming the gauges are off by a constant 170 (or 184, whatev) but are you sure it doesn't change proportionally.... so that the higher the temp goes, the farther off it gets. And if that is the case, how is stacking resistors going to affect that? Is it going to bring it the reading down to some ratio of what the temp unit is sending (how I would expect it to work; this is how an inaccurate speedo behaves) or reducing the temp readout by a constant temperature.
This just seems like something you'd want some precision on... I mean 20 degrees can be the difference between your fan kicking on at the right time or your bike overheating. (I know the fan doesn't kick on from this sensor, just illustrating the jump 20 degrees represents)
I dunno... just throwing it out there.. hope it contributes to the discussion.
Old 12-16-2009, 04:05 PM
well i can tell you 3 reasons on why i want to at least attempt this
1) it will be interesting to find out the questions your asking about proportionality, and fun
2) it will give me a better reading than 270* blinking
3) the annoying temp light will go off and stop annoying me on the highway
hell even if its 50*off it would still be better progress, no?
Old 12-16-2009, 04:19 PM
Michael S's Avatar
Yeah as long as I can get it under the 270 mark. Maybe I can get pretty close to accurate around the proper operating temp. I don't care if it shows 50 degrees and it's 50 degrees outside. So our window of accuracy can be pretty small (+/-30 degrees.)
Old 12-16-2009, 06:25 PM
i bought some rheostats at radio shack today
ill let you know about the outcome tomorrow
Old 12-16-2009, 07:39 PM
Michael S's Avatar
Awesome
Old 12-16-2009, 10:30 PM
rothjl749's Avatar
Well, it appears chuck here had the right idea. After my testing I ended up with the following results.
F3 Thermistor:
115 deg - 184 ohms
140 deg - 128 ohms
Ohm readings that were required to get proper reading on F4i gauge:
115 deg - 6490 ohms
145 deg - 4030 ohms
So, obviously it is proportional and simple resistors won't do the trick. When I would set the gauge to the water temp with the rheostat, I could take the sensor out of the water and it would only change like 1 or 2 degrees.
I am out of ideas.
Josh
Old 12-17-2009, 01:36 AM
F3 Thermistor:
115 deg - 184 ohms
140 deg - 128 ohms
115 deg - 6490 ohms
145 deg - 4030 ohms
I am out of ideas.
Josh
i guess no variable resistor?
hell i might as well just cut it off then, at least then i wouldn't have to worry about it nagging me anymore
Old 12-17-2009, 08:36 AM
Michael S's Avatar
I'm going to still work on this. I was looking at a digital resistor. It allows you to set specific resistance at certain temps. And you can set up to 100 different "taps". This way you can get extremely accurate if you want.
rothjl749 do you know the correction needed at around the 200 deg mark? I just need some more correction points to dial in. if not I can check. Thanks!
Quick Reply: Temp Sensor with f4i gauges
