Temp prob?
It's only moving a few mm and not even getting into the white box after 15min tick over. I checked the thermo housing senso for corrosion and it's clean. Fans haven't come on either, which worries me. Daytime Temp is 13 degrees here at the moment.
this is a fun one but dont worry im here
check these in any order you see fit
liquid actually in rad
thermostat itself is opening and closing
follow thermostat wire along the bike to check for any grounding out that may be interrupting the signal
check connections to the rear of the clocks
the fans have a switch on the rad and the temp is taken from the thermostat area so fans can come on even if thermostat isnt working so could be paranoia, might want to go ride it for a little bit say 4 miles minimum then sit it on idle for 10 minutes i know my fan comes on after 4 miles of riding and 10 minutes of idle but the temp gauge only seems to go up in the last 2 minutes
Any chance an airlock could be the culprit? I'm guessing if I take the stat itself out that it'll be a replacement job?
oh, have left it ticking over for ages and no difference.
Cheers.
Not familiar with the F3. Are you saying its not getting hot, or its getting too hot?
It says you have coolant in the rad, but is it circulating? Feel the lines, are they hot? There could also be an air pocket in the cooling system....I am just speculating here based on what I read in the posts already. Hope your get it sorted.
-Poss
-Poss
I took Annie, (my 98 600 f3) out for a proper ride today Did a 100 mile round trip. It was in the upper 60's. While i was at highway speeds the temp guage barely moved up. But when i got in stop and go the temp needle climbed about half way but went back to the bottom once i start moving again.
Hope this helps.
Hope this helps.
Cheers lads. It's not overheating, I'd say from experience that the engine temp feels similar to any other bike I've had. It's def not to do with it reading cool while riding, the gauge needle doesn't change on tick over after a 20mile blast.
Good thinking Poss, never even twigged about feeling the hoses! I'll try that and also go through the coolant bleeding procedure. Thanks.
By boil, I assume you mean remove and clean?
