Syncro?
So I cant get into 2nd gear past i dont know 7 grand, my friend is a VERY motor savy... when it comes to cars. And he says if it was a car he would say my syncro is toast. SO anyone had this problem? Is it best to give it to a shop and let them take the tranny apart or try to find a new tranny? ANY thought VERY appreciated!
Yeah it only happens when I am trying to get into second gear once it starts to get up around 7g... the guy I bought it from said the carb needed to be cleaned and I havent done it yet but would that really prevent me from shifting from 1st to second?
According to the manual check these things.
1 - Ignition timing and valve clearance.
2 - check the fuel line for clog
3 - Check for clogged jets
4 - check valve timing
5 - Check vavle spring
6 - Buy a new motor (j/k)
Keep us posted.
Keep us posted.
I think we need more detail - specifically about what doesn't work.
The way I read this, is that engine runs and revs fine - you have no problem accelerating up to and well past 7,000 in first gear - but if you try to shift into second when you're over 7grand, you can't.
I presume you're not only riding around in first gear, and that you have shifted successfully into second gear at lower RPM. Does the problem occur when you go over 7 grand in 2nd, then shift to 3rd (or any other gears for that matter)? Does it work, but it's rough?
What actually happens when it won't shift? Is it just a failed shift that ends up with you in neutral?
