swingarm sliders?
RE: swingarm sliders?
Don't necessarily have to get mounts welded on. You can take an aluminum block that fits exactly inside the swing arm and tap a hole in that, then drill a hole in the s/a so you can get the bolt thru and thread into the block. Thats what I did and its worked great. Just make sure the block is EXACTLY the right size to slide completely into the s/a.
