sputtering ???
Old 01-21-2009, 11:39 PM
89cane's Avatar
Default sputtering ???
so i did a tune up on my bike changed the oi,l plugs, and cleaned the filter. Now it sounds perfect at idle and in neutral it taks up all the way just fine. Same in any gear with the cluch in no matter the speed but when its under load it just starts to sputter kinda like its out of gas or not getting spark all the time. i think it is somthing electrical because the fuel system is fine when there is no load.
any ideas would be apprecaited
thanks
Ryan
Old 01-22-2009, 09:51 AM
grizzly's Avatar
Default RE: sputtering ???
did you put the plugs in the right cylinder?
Old 01-22-2009, 11:45 AM
marc0011's Avatar
Check the rubber insulators at the base of your carbs. I was having an issue with my bike where it would idle just fine but when attempting to ride, there was a severe lack of power. I went and tightened all the bands and botta bing botta boom... I had my bike back in order. Another thing you might want to check is that all the air hoses are connected correctly.
Old 01-22-2009, 01:08 PM
89cane's Avatar
i have checked all of the air hoses to make sure they were good. and the plugs are all in the right cylinders. i guess ill try the intake boot bands and clean up the carbs when im in there next i plan to replace the cct as well and see what happens then.
any more ideas would be apprecated
thanks again
Ryan
Old 01-22-2009, 08:40 PM
Empire929's Avatar
Is it dieing at all? My F3 started to sputter then it would die out on me every now and then. The problem was that the rectifier was starting to go bad and when it went, it went big. but 100 bucks and 15 mins of install time made her run like new.
Old 01-22-2009, 10:34 PM
89cane's Avatar
no it doesnt die it just sputters.
Old 01-22-2009, 10:56 PM
f3BikeR's Avatar
Does it ride the same?
Sputtering might be a sign of running lean or incorrect plug gap...
Old 01-22-2009, 11:32 PM
89cane's Avatar
it has slightly less power before the power band but when i hit where the power band should be it just sputters unless i ease off of it then get back on it slowly. my thought was that the carbs may have been adjusted when the filter was dirty so it was running lean but it acts alot like when its out of gas you know hitting every once and a while
thanks again for all the imput and help
Ryan
Old 01-24-2009, 02:04 PM
Conrice's Avatar
i would also check the pilot screws,mine did that when i would have other people on my bike. maybe a half - full turn out would cure the problem.
edit- or you could turn the spark plugs down a degree (or setting, whichever one it is). that will give you less power, but you wont have to worry about running lean.
Old 01-24-2009, 07:31 PM
89cane's Avatar
ok when i take it apart again i will check the pilots too thanks
Quick Reply: sputtering ???
