Spark plug trick?????
Is there an easy way to change the spark plugs on a 98 f3??? I know to do the one on the right side and then do the other three from the other side because of that hump on the motor. Fo you guys use swivels, how many extensions??? I tried using a standard 5/8 plug socket and a 2 inch extension and that damn black box was in the way above it. There had to be a way to do this easier than removing the tank, airbox and then that duct work that was in the way. I already had the tank off earlier today and cleaned the k&n and put it back together. Just wondering if there is a trick?? Thanks
RE: Spark plug trick?????
I use a spark plug socket. than a 2 inch extention, and then an elbow joint and then another extention 2inch for the first two plugs and a 4 inch for the 3rd plug. I really don't know the proper name of these parts. but that is what I use.
It is a pain in the ***...so have fun.
when i changed my plug's i took off the service door pulled each boot one at a time spray'd some compressed air down the tube clean out any dust or dirt in there, dropped the socket, then hooked up the extension, put the wrench on, loosend the plug, took the wrench off, pulled the extension up at an angle so i could get my finger on the socket, popped the extension off, pulled the plug and socket out....took about an hour pain in the ****, but it worked, i diddnt have a spark plug socket that may have helped things a bit
thats what I was doing last night untillI got to the inner two plugs. I didn't have an extension that was short onough or a swivel. It def. is a pain to do. Hopefully the plugs will solve my problem. wasn't the feul filter, fuel pump or the k&n air cleaner. Hopefully sparkplugs.
I use a spark plug socket with the rubber "grabber" inside it, a 3" extention and a long handled socket wrench with a twist handle(makes starting and backing out a breeze) Never had a clearance problem. You just have to put the tools in one at a time(socket-ext-wrench).
