Someone please help!!!
I got this F3 and it wouldn't start. It seemed to be flooded.... for awhile it would start but just idle and then either shut off or when i'd try to open the throttle at all it would shut off.. then it just quit working completely and only crank over but no pops or anything. SO i took the carbs off, cleaned the jets and bowls, then it worked!... a day later I started it, it ran for about 5 minutes half decent, and it shut off and never started. No pops or anything, just cranking. Two days later, I went out to start it, it popped a couple of times and nothing, so I cleaned the carbs again. I checked the spark, and the wires, they all seem fine. The fuel pump is also working, as I tried to bypass that and it still didn't work. Does ANYONE out there have any ideas? I'm really frustrated
Why would the bike just crap out? I also forgot to mention that from when I ran the bike and drove it, I forgot to hook a hose up so coolant ran out, but the temp was fine and I did not even drive it for more than 10 minutes. So I was maybe thinking there was a coolant sensor so I added coolant but still nothing. So the story still goes as... 1st day I had it.. would only start and idle and shut off by itself or when I opened the throttle (even just a little). Then it quit completely and only cranked over, so i cleaned the carbs and jets. After the clean, it started up and I was able to drive it for about 10 minutes and it ran fine-- some coolant leaked out... Shut it off and put it in the garage. The next day I went to to get it from the garage, it started fine, I drove it to my house (which is like 30 yards), it shut off and wouldn't start. So finally I ended up pushing it back to the garage, and it would only crank so I left it. The next night I tried cranking it over and there were a few loud backfires with occasional fires like it wanted to start, then after awhile.. nothing. Took the carbs off, cleaned everything thoroughly again, nothing. It will only crank. Fuel pump is pumping, tried bypassing the fuel pump and still nothing. I don't know how timing could of gotten thrown off as it ran fine that one day. I dont understand what it could possibly be, but its frustrating, I have all new plastics and misc parts sitting there, but the bike WILL NOT RUN!!!!
I also checked the spark by running a bolt from the inside of the wire to the frame. And it does spark. The plugs are also new. Why would it just run fine then not run. If somebody's help gives me the a running result, I will send $20 dollars to them because this is just too frustrating.
Still have not got bike in running condition. However I took the carbs off AGAIN and sprayed out the float valve holes just to be safe, then put everything back together. It will crank with a few backfires and act like it wants to start. Still will not actually start. Hmmmmmm. Well for now- at least theres more hope than before I guess!!... if you guys have any other suggestions just throw em out here! Thanks
