rims?
This is no direct bolt in. I'm working on installing a 900rr 5.5" rear rim on my F3. The rim looks the same just wider. For it to fit, the crush hub has to be milled down. You have to remove alot of metal to get it to fit inside the swingarm first of all. Then you have to take more off so the sprockets lineup right.
I'll post up some pictures of the hub, before and after. I didn't use a lathe, just to prove that it can be done without one. I used only a drill press, milling vise, 1 milling bit (7/16), grinder with cutoff and flapper wheel.
Planning on making the axle spacers this weekend.
Ok since I'm getting PMs about the 900rr rear rim swap. I'm planning on finishing up the spacers this weekend. After that I post a complete write up. This is one of many things that is being done to the race F3 over the winter. Ground up complete rebuild including a complete engine rebuild and modifications.
