Regulator/rectifier 1995.
Old May 15, 2025 | 04:09 AM
600rbc's Avatar
Default Regulator/rectifier 1995.
Bought a after market ebay regulator which is worse than orginal.Im looking for a decent one but not stupid money any suggestions i would be greatful thanks for reading.
Old May 15, 2025 | 11:21 AM
Try here:
https://www.electrexworld.co.uk/
Unfortunately you will have to pay a bit to get a decent one c.£100. Give them a ring ads see what is available as you would ideally want a mossfet R/R as they generate less heat than the OEM type.
Old May 15, 2025 | 01:17 PM
600rbc's Avatar
Thank you for reply
Old May 16, 2025 | 09:24 AM
clippy's Avatar
I upgraded to a mosfet regulator off a yamaha fjr. These are better than the stock 'shunt'-type regulators that came from the cbr. Very simple, just disconnect the pins from the r/r connector and plug it right into the used regulator. Very cheap too I got mine for $25 and the voltage is very stable, reading a 14.2 volts from idle to 6krpm, and probably understressed as the fjr is a touring bike designed to support lots of farkles and I don't run any accessories. Best part is since no cutting required, you can fully go back if you'd like.
some light reading if you are interested in more: https://www.superhawkforum.com/forum...why-how-25117/
raiden
Jun 1, 2009 07:21 PM
hades
May 8, 2008 02:24 AM
dunn929
Apr 18, 2006 07:12 PM
mavric_337
Apr 5, 2006 09:17 PM
