re-attaching throttle cable
I know this has been covered before..but I still need help. I'm putting my carbs back on my F3 and I have the cables hooked up, but can't get the cable to snap back. The carbs are out and the throttle is apart at the grip. Hooking it up wasn't bad, but it stays open when I twist the throttle. I'm not even 100% sure I have it routed the right way. The cables come off the carbs and go through the guide at the frame and around the fork tube. I've done this once before and although difficult..I didn't have this much trouble. Any advice?
thanks..
thanks..
Thanks for the replies and pictures. I was putting the cables under the front brake hose, but once I fixed that..it still doesn't work. Not only does the throttle not snap back, it is pretty hard to turn and basically stays open. I took the cables off completely and I noticed when I go to move the throttle wheel on the carbs with my finger, it moves pretty hard and definitely doesn't snap back there either. Is this normal? I never really moved this wheel before so I'm not sure how it should act. I would expect it to move a little easier though.
On a side note...I'm putting the carbs back after replacing some o-rings at fuel joint pipe. I did take the carb connecting bolts out and took carb 1 away from 2 and 4 away from 3...just enough to change the o-rings. Could I have over tightened something?
