Ram air issues... Not looking forward to this fix
So, upon try to budge some stuff around I managed to pop the elbows for my main ram air intake off last night. I threw them to the side and went to bed, lol. Am I going to have to drop the engine to get this rectified? I just got done two weeks ago putting this bike back together and I would prefer not to have to drop the engine again.
are you talking about the two elbows going into the airbox?
if so then there is no need to drop the engine, just need a heat gun and a little patience to get them back in. |
Originally Posted by sjona2011
(Post 1282223)
to heat up the rubber, makes it a hell of alot easier to get them in.
So they don't require any type of sealant of any sort? just kind of make the rubber pliable and fit them in, they expand and seal up the connection?
sealant wouldnt hurt, when i did mine i didnt bother because it was a real tight fit.
If you need any high resolution pictures of the routing and assembly of the whole DAI ram air system, let me know as I have taken many pictures of mine during strip downs etc...
Jules |
Hi All,
Allthough i do realise this is an older topic i am struggling getting the tubing back into place. Especially the way the tubes are fitted underneath the cockpit is a bit unclear to me. Now does the cockpit have to be removed to install the tubes or can it be done without removing it? I got the bike with all of the tubing taken off so i have no idea how it was originally fitted. After one of the members here on the site sent me the nice exploded view i realised the tubing was not fitted correct. but still it would help if someone could provide me with some pictures on this. Julliet stated she has some HR pics if needed but not sure how i can send a message to her as a PM so i drop this question in here hoping to hear from any of you.. So thanks in advance McSilver / Frank. |
Originally Posted by Juliet
(Post 1282639)
Jules I worked out the general lay out but the cockpit area is still a mess... so any visual help with this is highly appreciated. And i wonder if the cockpit has to be removed in order to install or if this can be done without having to remove all of that.. |
