r/r replacement question
So... anyone have input on this situation? I tried wiring it up with the two positive connected to my single positive, and the two grounds connected to my single ground -- and it seems to (somewhat) work as in it heats up as usual but my bike is still dying randomly. Sometimes sooner than others.
Any ideas? Any solutions? Can I skip one of the pos/ground? Am I not getting enough juice to the two wires from my single wires? I really dont want to have to get a new regulator would like to make this one work.
my 2c
What kind of bike did your 7 wire R/R come off of? See if you could find the wiring diagram for the bike it came off and double check to make sure that you're right in assuming that the extra two wires are just extra positive a ground wires. If they are, you're current configuration is correct. If not, let me know what you find out about the other two wires and I'll try to help you from there.
What I did was connect the two power from r/r and then connect that to the power from bike. Same with ground, connected the two, then connected to my bike. In theory it should work, but I dont know what else would be causing it to randomly die as such.
