R/R ?
Old Aug 7, 2008 | 06:40 PM
SilverF3's Avatar
Default R/R ?
Ok i burnt out my cheap ebay RR. Now im doing a swap to a gxsr, but my ? is will the bike not run or not stay runnning with a bad RR. Thanks the bike will start after a sec but wont stay idling or running. But starts up and will run no problem.
Old Aug 8, 2008 | 09:02 PM
MrBomb's Avatar
Default RE: R/R ?
[sm=insomnia.gif]
Old Aug 8, 2008 | 09:20 PM
redzintimidator's Avatar
Default RE: R/R ?
"but wont stay idling or running. But starts up and will run no problem."
so will it stay running or wont it?...
Old Aug 9, 2008 | 06:49 AM
Sproutf3's Avatar
Registered Users
Default RE: R/R ?
fried r/r = no battery charge dont let rpm drop below 3ish and it will get you home
Old Aug 9, 2008 | 03:37 PM
SilverF3's Avatar
Default RE: R/R ?
It wont stay running or idiling under 3 if i give it gas or hold it above 3 it will stay running. IS this the R/R. Yes the battery is dead also. but the stator is new along with everything else, aside from engine sensors.
Old Aug 9, 2008 | 05:07 PM
Adionik's Avatar
Default RE: R/R ?
The bike will stay running even without an RR until the battery is fully drained. One time I had it idling and it just ran till it killed the battery.
Old Aug 9, 2008 | 05:42 PM
SilverF3's Avatar
Default RE: R/R ?
So should my bike start up and run fine with the bad R/R. It started up and ran fine no problems untill this. I checked and the wire that burnt out last time is the same one that burnt out this time. I installed the old R/R and the bike acted the same. Any ideas
Old Aug 9, 2008 | 10:20 PM
lonewolfcbr's Avatar
Default RE: R/R ?
if the battery is dead...its not going to start.....
Old Aug 10, 2008 | 09:57 AM
SilverF3's Avatar
Default RE: R/R ?
no i charged the battery and it starts after a sec but i have to give it gas and hold it over 3k to keep it running. And it wont idel, and if it does idel,when i give it gas it drops and dies. never happened till one night i was riding and the whole bike died and its been doing this ever since.
Old Aug 12, 2008 | 01:30 PM
jahnaboi's Avatar
Default RE: R/R ?
Just get a new r/r and charge your battery and you'll never have that problem again. End of story. Your problem is your r/r. You could buy a used 97-2000 gsxr r/r and it will work. I have a 2000 gsxr one and it works wonders.
