Questions about Jets
Old Oct 25, 2010 | 01:19 PM
christian_rider's Avatar
Default Questions about Jets
I got this F3 from trading my boat. I was told that the carbs on the bike were rebuilt approximately 3 months before I got the bike. I have replaced the Air Filter to a K&N and it has an aftermarket exhaust (micron)on it. I took the bike over to the shop because it noses down on accereration in all of the gears except for first. I was told that I needed to have my bike rejetted because it's running rich. First, is this true and second if it is true, what jets should I purchase to put in there. Third, can I just clean and reuse the jets that are already there? Any help would be appreciated.
Old Oct 25, 2010 | 01:55 PM
intiractive's Avatar
what do you mean "noses down on acceleration" ??
Old Oct 25, 2010 | 04:24 PM
espelade's Avatar
If its running rich you would need smaller size jets. Though adding a filter and slip-on typically results in a lean condition because it increases air flow.
This is my poor-man's test to check if its rich. Tape a piece of paper to a fence or building- back your bike up so the exhaust is pointed striaght at it. With the bike warmed up and the choke OFF-Give the throttle a few blips. If there is black or gray deposits on the paper its running rich.
You may also check your air solenoid. (use the search function to find a how-to on bypassing it)- a fault with this would cause a rich condition above 12 mph.
One thing to remember is RPM is what gauges a carburetor engine's running condition. Gears are indicative of the transmission- though speed will factor the air flow the bike is receiving. Feel for a common symptom between RPM bands in each gear.
Old Oct 25, 2010 | 04:29 PM
The bike decelerates very fast. Almost as if I'm pressing the front brake. Then it will sputter very hard and will not acclerate.
Snapp
F2 Tech
Apr 12, 2011 09:57 AM
Aweasel
Jun 23, 2008 06:09 PM
daddydonuts
Jul 12, 2007 10:29 PM
sloppyjones
Jun 1, 2007 11:19 PM
kevvydude
Jun 14, 2006 07:44 PM
