Question on seat valves.........????
Hi guys...i am finally doing some work on the head..boring...for oversize new piston kit.....but the seat valves are super tight.... the question is..Do I have to really have to replace them..and if I do..is it only using the oven the easiest option to remove them???? Thank you a lot for your input.... Ivan. L.A:icon_hyper: |
your best bet is a valve spring compressor,then if there all within spec, just re-lap them into the head, or get a machine shop to do the whole job for you.
hope this helps, Ant. |
You don't replace valve seats unless their outside specs. If you have to replace them, get a machine shop to do it.
| All times are GMT -5. The time now is 12:13 AM. |
